Activity Forums Adobe Premiere Pro Why is Premiere CS6 playback being so slow?
  • Why is Premiere CS6 playback being so slow?
    Posted by Joey Deutsch on August 17, 2013 at 5:43 am
    I am doing a project on the go, so I started using my older Early ’08 Macbook Pro to edit. I have done projects on here before, and they have been perfectly fine. I even convert all my footage to ProRes, but for some reason, everything is very laggy! I don’t even have effects on my footage, and I cranked the preview resolution down to 1/4, but when I try to scrub through the timeline, it is verrry unresponsive! Like I said, i’m even using ProRes on these clips. I do have a lot of clips to edit, would that be the cause? I hope someone can help.
    Joey Deutsch replied 13 years ago 2 Members · 3 Replies
  • Joey Deutsch
    August 17, 2013 at 4:58 pm
    Problem solved! Before, I was trying to edit footage from an external USB 2.0 drive. I copied the footage to my main drive, and there was no lagging! Lesson learned, don’t use slow drives. Hah!
  • Shane Ross
    August 17, 2013 at 5:59 pm
    Where is the footage stored?
    Shane
    Little Frog Post
  • Joey Deutsch
    August 17, 2013 at 8:26 pm
    It was on an external 1TB hard drive. I think my workflow will now be to import the raw footage from the camera to the 1TB drive, then when I convert the footage to ProRes, I will set the destination to a temporary file on my main drive. Then the original footage will be safe and untouched, while I can edit with the copies.
