Activity Forums Maxon Cinema 4D Why is only one side of this visible?
  • Boston Cainfra
    January 19, 2023 at 12:51 am
    Hello Jon Simpson
    There’s a solution to that
    I textured your butterfly wings and it flapped without the texture going on or off
    Check the video of the butterfly flapping without the texture going on or off
    Here is what I did
    I simply deleted the old texture and created new one and also also delete other tags as well
    Try deleting the texture and tags then create a new but if the problem continues then you have to try out different render engines aside the one you’re currently using which will surely worked out for you 100%
    You you want to know the render I used then it was C4D standard render
    Let me know if you have any other questions
    THANKS
