Activity Forums Adobe Premiere Pro Why is my nested sequence being resized upon export?
  • Why is my nested sequence being resized upon export?
    Posted by Joel Morehouse on March 27, 2013 at 5:15 pm
    I am working in a 1080p timeline and have brought in 720p footage that has been cut together, rescaled to fill the frame, and nested. When I bring up the export window, though, the scaled nested sequence returns to 720p, and no longer fills the frame. Even when I export the entire sequence in 720p, the nested sequence scales down to only a portion of the frame. What is going on?
    I’ve attached two images to clarify the situation. Thank you all in advance for your expertise.
    Paul Neumann replied 13 years, 6 months ago 3 Members · 3 Replies
  • Cody Walters
    March 27, 2013 at 5:59 pm
    Do you have scale to frame size checked on your clip? If so, it looks like Premiere is ignoring that attribute of your clip when you pull up the export dialog box.
    For a quick fix, I would uncheck Scale to frame size on the clip and under effects scale the clip manually. See if Premiere retains that adjustment upon exporting.
    You may want to trash preferences and see if that fixes the issue.
    Cody Walters
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS6 Master Suite
    Panasonic HVX-200
    Canon 7D, 60D
  • Joel Morehouse
    March 27, 2013 at 7:18 pm
    Thanks for the advice! Manually scaling it worked. Not sure what the deal was.
  • Paul Neumann
    March 27, 2013 at 8:46 pm
    Tried to duplicate this and wasn’t able to. I put 2 layers of 720p on a 1080p clip/sequence, set both clips to “scale to frame size”, nested them and put them back on the 1080p timeline. Rendered out just fine. One note, checking “scale to frame size” on the nest had no effect whatsoever. So that function seems to be strictly clip based.
