Activity › Forums › Adobe Premiere Pro › Why is my homebuild still slow?
  • Why is my homebuild still slow?
    Posted by Kevin Thomas on November 22, 2012 at 12:38 am
    Specs
    CPU : 3930k
    fan:COOLER MASTER Hyper 212 EVO
    GPU : EVGA GeForce GTX 580 (Fermi) 3GB
    Mobo: ASRock X79 Extreme4 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    RAM : G.SKILL Ripjaws Z Series 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
    Case: COOLER MASTER Storm Series Trooper
    PSU: RAIDMAX RX-1000AE 1000W ATX12V v2.3
    Monitors: LG IPS235 and HPvs17e
    Other than the problems with freezing I have, I figured this would chew through Premiere, but it is still slow when I use simple effects. What gives?
    Kevin Thomas replied 13 years, 10 months ago 4 Members · 4 Replies
  • Tero Ahlfors
    November 22, 2012 at 6:51 am
    You mentioned everything except your storage and what format are you having troubles with?
  • Al Bergstein
    November 22, 2012 at 5:16 pm
    Just for reference, I’ve found (in the past), that freeze ups on these kind of build it yourself computers (I’ve built dozens over the years), usually end up being a motherboard, memory, bios upgrade, or some other kind of hardware/ OS software related issue, not a ‘bottleneck’ problem and rarely related to a package such as Adobe.. As a starting place, make sure your bios has been upgraded if it can be, as the manufacturer finds problems after shipping, they’ll update. I’ve finally given up on building them myself…not worth my time troubleshooting the issues. As to speed, Tero has a good starting question. Good luck…
    Al
  • Angelo Lorenzo
    November 22, 2012 at 6:45 pm
    Almong with Al’s suggestion, look at things like SATA level in Bios, CPP throttling/overclocking, and RAM voltage.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Kevin Thomas
    November 23, 2012 at 9:27 pm
    @ Tero Ahlfors
    Sorry to respond so late, I’ve been watching my nephew and niece.
    I have this for OS and Programs :
    Western Digital 320gb 7200rpm
    https://www.ebay.com/itm/WESTERN-DIGITAL-WD3200AAKX-001CA0-HARD-DRIVE-320GB-SATA-3-5-DCM-DHRNHT2AHN-/170822545752
    I have 4 of these, 2 each in striped software RAIDs:
    Seagate Barracuda ST1000DM003 1TB 7200 https://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
    and I just realized my CD/DVD drive is no longer recognized.
