Activity Forums Apple Final Cut Pro Legacy Why is my HDV footage 720×480?
  • Why is my HDV footage 720×480?
    Posted by Spencer Schilly on June 6, 2008 at 2:35 pm
    I am trying to capture HDV footage using a Sony GV-HD700 deck that I rented.
    Footage was captured in this project months ago and the compressor in the browser clips says HVD 1080i60. Frame size: 1440×1080…
    Now when I capture capture it keeps telling me that the compressor is DV/DVCPRO-NTSC frame size 720×480. I think this is happening because the only way i can get FC to recognize the deck is when I first tell it to capture NTSC… but then I switch the easy setup to HDV/HDV -1080i60. If I open final cut with the deck and tell it to use HDV/HDV -1080i60 first then it will not recognize the deck… I have tried for hours and this is the only way i can get it to capture this footage and recognize the deck – by first saying it is NTSC.
    I have tried many different tapes. It was the same DP as from months ago. I know they are HDV. I have trashed preferences, restarted FC and computer several times, turned off and on the deck etc.
    Any thoughts??
    Spencer Schilly replied 18 years, 3 months ago 2 Members · 2 Replies
  • Tom Wolsky
    June 6, 2008 at 2:42 pm
    Sounds like you have the deck set to output DV. Make sure it’s using HDV out and HDV control not DV.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Spencer Schilly
    June 6, 2008 at 3:00 pm
    YES!! thank you. that was the problem. I had DV out turned off but there was some iLink thing that I needed to turn off as well…
