Activity › Forums › Maxon Cinema 4D › Why is image blurred when added to an object
  • Why is image blurred when added to an object
    Posted by Moomal Haris on April 28, 2019 at 2:16 am
    Hello, I just started learning to use cinema 4 day (first day)… I was trying to add an image to a plane object with cloth effect l. I am able to get everything fine except one major issue…Whenever I add an image (jpeg) it comes out blurry… I have tried to play around with different sizes… always blurry.. however when I add the same image to the background it’s absolutely fine!! (Ex… if I am making a flag and try to add an image to that flag the image looks really blurred) any help? What am I doing wrong ?
    Moomal Haris replied 7 years, 5 months ago 2 Members · 2 Replies
  • Brian Jones
    April 28, 2019 at 3:45 am
    in the material tag (once you place the material on the object) there is a setting in the Editor tab ‘Texture Preview Size’ it’s default value is Default and you can increase the values to see if it gets sharper. I don’t know the details but the help says the default is dependent on the graphics card so depending on what yours is your results may vary. Or at least as I read it. The background object is unaffected by that setting so it will always only be affected by the quality of the image. If you have clear background object the image must be big enough, so try the Texture Preview Size.
  • Moomal Haris
    April 28, 2019 at 6:49 am
    Thanky you so much!! It’s working 🙂
