Activity Forums Adobe Encore DVD Why is Encore transcoding footage already at DVD spec????
  • Why is Encore transcoding footage already at DVD spec????
    Posted by Jason Brown on January 2, 2007 at 4:52 am
    Hey Guys,
    I’m real stumped here…I have footage that was recorded into a DVD recorder and I’m taking the clip and authoring a menu onto it.
    For some reason when I put the footage into my project window, go into the transcode settings and set it to *don’t transcode*. It still transcodes the footage when I build the DVD. It is 720 x 480 29.97 with multi-plexed AC3 audio, with the extension .VOB (I’ve changed it to m2v and to mpg…but neither does anything different)
    I even went into the project to the …Cache\Temp_Transcodes folder and used the already transcoded m2v file and it still re-transcoded it.
    Any ideas?
    -Jason
    Neil Wilkes replied 19 years, 7 months ago 4 Members · 3 Replies
  • Roman Melekh
    January 3, 2007 at 5:07 am
    try to import to encore demuxed files – separate video and audio
  • Mylenium
    January 3, 2007 at 5:52 am
    Multiplexed files are not valid authoring files. Demux them like Frippy said. Simply renaming a VOB doesn’t make it a “clean” MPEG-II file, you know…
    Mylenium
    [Pour Myl
  • Neil Wilkes
    January 25, 2007 at 1:19 pm
    Additionally, DVD recorders are often not DVD-Video compliant either.
