Activity Forums VEGAS Pro why is 16×9 footage from deck capturing at 4×3?
  • why is 16×9 footage from deck capturing at 4×3?
    Posted by Adam Rose esq. on December 21, 2006 at 11:44 am
    the saga continues.
    have J30 deck working. can capture into vegas. project settings are PAL widescreen. Vegas capture has aspect ratio in preview window of 16×9
    why do the clips show up on timeline as 4×3 within 16×9 window, ie squashed on the sides?
    when playing clips in WMP, are def 4×3.
    material shot on 16×9 with digibeta. settings were correct 100% on camera.
    danke
    Adam Rose esq. replied 19 years, 8 months ago 1 Member · 1 Reply
  • Adam Rose esq.
    December 21, 2006 at 11:48 am
    ok, read in manual that i need to set project media manually to 16×9. doesn’t make sense that i should have to do that with each clip
    what am I doing wrong? prob very simple issue, but was up until 5am trying to get deck to work
    TIA muchly
