Activity Forums Adobe After Effects Why doesn’t the “Difference” blending mode work from inside a precomp?
  • Why doesn’t the “Difference” blending mode work from inside a precomp?
    Posted by Pietari Virtanen on April 17, 2018 at 12:53 pm
    Hi!
    I’m having a problem with the “Difference” blending mode. Basically I have a picture with the Normal blending mode, and on top of the picture, I have a video with the Difference mode, and it shows the difference between the two in the comp preview window and everything is all well and good. When I precomp the two layers, the main comp preview window now just shows the picture layer, it’s as if the video layer had vanished. If I open the precomp, both of the layers are still there and it shows the difference between the two layers correctly in the precomp’s preview window, but if I go back to the main comp, it still doesn’t work.
    If I render out the precomp, it doesn’t render the video layer either, it just renders the picture.
    Sorry if the explanation is a bit confusing. Can anyone help me out?
    Pietari Virtanen replied 8 years, 5 months ago 3 Members · 3 Replies
  • Walter Soyka
    April 17, 2018 at 2:00 pm
    If Edit > Purge > All memory & disk cache… doesn’t work, can you post back with some screenshots that show us what you’re seeing? The complete Ae UI for both before and after precomping?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Roland R. kahlenberg
    April 18, 2018 at 12:36 am
    IOW, the Preview in your PreComp looks as expected but the render produces something else?
    Other than what Walter has suggested, you should also post screengrabs of your precomp’s Timeline and the ‘final’ comp’s Timeline.
    PathSlicer – Advanced AE Shape Layer Effect
    https://www.broadcastgems.com/pathSlicer
    – create highly customizable custom animated typefaces
    – create amazing transitions
    – create cool lower 3rds and panels
    – create burst effects
    Do it all on a single Shape layer with minimal keyframes.
    TypeGEMs – The Most Complete Type Tool Effect for AE
    https://www.broadcastgems.com/typegems/
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    BorisFX mocha Certified Instructor
  • Pietari Virtanen
    April 18, 2018 at 7:14 am
    The problem was solved, I had accidentally made it a guide layer and that’s what was causing the problem. Thanks for the replies, I really appreciate it.
