Activity Forums Adobe After Effects Why does The Wiggler sometimes work and other times not?
  • Why does The Wiggler sometimes work and other times not?
    Posted by Daniel Haskett on May 12, 2005 at 2:18 am
    Hi there
    Ive just been doing some wigglying with opacity on layers, but it was working fine and minute ago and now its not allowing it anymore, I just dont understand what I could have done wrong?! If anyone has any ideas Id really appreciate it!
    Dan
    Steve Roberts replied 21 years, 4 months ago 3 Members · 4 Replies
  • Joe Chao
    May 12, 2005 at 2:25 am
    The wiggler required at least 2 key frames.Check that you have added 2 key frames to the layer,and select the two key frames,then try the wiggler tool.Is it working now?
    My name is always misread as COW……..:)
    so I got this ID:
    friendcao2004@hotmail.com
  • Daniel Haskett
    May 12, 2005 at 2:29 am
    thanks for your replies, appreciate the help, but yeah i always do it with 2 keyframes…:(
  • Joe Chao
    May 12, 2005 at 3:48 am
    Have you read the help file about wiggler?May be you can find some information helpful.
    And if everything is normal,how about reboot your computer?
    so I got this ID:
  • Steve Roberts
    May 12, 2005 at 4:08 am
    You know, since Expressions were added, I haven’t used the Wiggler once. I use the Wiggle expression instead. It doesn’t lock you into keyframes, and is quite variable.
    The Wiggle expression is under the expression drop-down menu, under “property”. For almost all applications, I’ve found that you just need a value for amplitude and one for frequency. Delete the other parameters.
    For more information, look for “expressing your wiggle” at the Adobe Studio.
    Steve
