Activity › Forums › Adobe Illustrator › Why does the Film and Video template have no background?
  • Why does the Film and Video template have no background?
    Posted by David Goodwin on January 13, 2017 at 1:24 pm
    This is how it looks when I create a new document. I’m not even sure where the artboard edges are, quite hard to see. It seems to be just a TV safe guide and transparency grid. The Photoshop version is the same.
    Vincent Rosati replied 9 years, 8 months ago 2 Members · 1 Reply
  • Vincent Rosati
    January 14, 2017 at 12:45 am
    What you are seeing is the Transparency Grid.
    View > Show/Hide Transparency Grid.
    However, if you hide the transparency grid, you might be under the false impression that your artwork has a background, which it doesn’t.
    If you want a background, you have to add it. Otherwise, you will have transparent areas in your art, which might be good for a title roll, for instance.
    Also look at View > Show/Hide Artboards.
    If you have snapping enabled, you can easily create a background with the Rectangle Tool.
    Further, if you create a document with the base components that you like, you can add that to your templates folder, thereby making your updated template a template that’s available to illustrator.
    Another note, those safe guides were deprecated in 2010 by the National Association of Broadcasters…
    https://www.nab.org/xert/scitech/pdfs/tv031510.pdf
    So, that might be another reason to create your own template.
    Vince
    *Please remember to Like an answer if it solves your question or gives you a good idea.
