Activity › Forums › Apple Final Cut Pro Legacy › Why does quicktime aspect ratio change from 16:9 on mac to 4:3 on pc?
  • Why does quicktime aspect ratio change from 16:9 on mac to 4:3 on pc?
    Posted by Philipp Figueroa on December 4, 2009 at 11:34 am
    When I outplay my master and the convert it to an MP4 the aspect ratio changes as soon as I open the file on another system.
    All the files have the right aspect ratio on my MAC (in QuickTime player, Preview and FCP) but they become 4:3 files as soon as I send them to the client via FTP or if I open them on a PC.
    How should i compress or outplay the files in order to maintain the right aspect ratio for all systems?
    here are the specs of my files:
    .mov (720 × 576/ DVC – PAL, Linear PCM, Timecode)
    .mp4 (720 × 576/ MPEG-4 Video, AAC, MPEG-4 SDSM, MPEG-4 ODSM, Hint)
    I guess this might have something to do with the anamorphic footage I am using but i would expect FCP to render/ compress it to the right aspect ratio as soon as I outplay.
    Please help..
    Philipp
    Philipp Figueroa replied 16 years, 10 months ago 2 Members · 2 Replies
  • Alan Okey
    December 4, 2009 at 4:41 pm
    [Philipp Figueroa] “I guess this might have something to do with the anamorphic footage I am using but i would expect FCP to render/ compress it to the right aspect ratio as soon as I outplay. “
    No, it doesn’t work that way. The only thing FCP does is change the canvas and viewer to show the anamorphic video with a stretch applied. It’s not affecting the original source files, simply distorting them on the screen to make them look correct.
    Export a Quicktime movie of your FCP project. Don’t use “Quicktime conversion,” just use the top choice, “export Quicktime movie.” This creates a movie file of your project using the current project settings.
    Next, open the exported Quicktime file in Compressor and convert the anamorphic source video to a square pixel 16:9 aspect ratio movie. 640×360 would be ideal. Compressor has several options for dealing with rescaling and cropping footage.
    I recommend opening up the Compressor manual spending some quality time with it.
  • Philipp Figueroa
    December 7, 2009 at 12:37 pm
    Thanks for your advice Alan,
    I was wondering if the possibility exists to generate a ‘Square Pixel’ master mov straight from FCP? Or is it only possible to generate other formats after converting the master file in to the right aspect ratio in Compressor? I convert our client films to a couple of different formats (flv, Mp4, wmv) and I though it is quite a waste of hard drive space if I have to rerender every master to a ‘true 16:9’ file before converting it. Not to mention that it takes additional editing time to convert the master every time…
