why does PP not take both audio channels?
When I create a multicam sequence from a camera source that has two different audio tracks – CC drops one , duplicates the other if you choose 2 tracks from the drop down box where you set the parameters for the multicam. if you choose 1 audio track it seems to combine them.
Does anyone know how to make this process of creating a multicam edit sequence that keeps both the original audio tracks from the first source selected ?
