Activity Forums Adobe After Effects Why Does My Zoom In Hook Around Like This?
  • Michael Szalapski
    June 7, 2018 at 1:37 pm
    It looks to me like the anchor point or position keyframes aren’t linear, but the scale keyframes are. If you select all of your keyframes, right-click, and choose keyframe interpolation and set them all to linear, does it go away?
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Kevin Ampofo
    June 7, 2018 at 4:58 pm
    They are both linear, which is why this is strange
  • Steve Bentley
    June 7, 2018 at 5:43 pm
    If you can upload the project we can take a look.
    Keep in mind that scaling is exponential – as you “zoom in” it gets faster and faster – when you scale something 200% it gets 4 times bigger. Scale it 4 times and its 16 times bigger; whereas a camera moving at a constant rate will look, well, constant.
    Also with a lens involved, as objects approach the edge of the frame they tend to warp a little as they “round” the lens. The effect is higher in the horizontal rather than the vertical due to the side edges of a landscape shaped frame being closer to the edge of a round lens. You can use the distort/optics compensation effect to simulate this – it really adds a nice true camera feel.
