Activity › Forums › Apple Final Cut Pro › Why does my timeline render everytime?
  • Why does my timeline render everytime?
    Posted by James Bayliss-smith on January 2, 2012 at 5:35 am
    Everytime I add footage to my timeline it has to render. Here are the properties of the video I am editing with according to Video Spec
    ***** Analyzed File Results *****
    *** General Parameters ***
    – Name: Yue Sao 43.mov
    – Container: MOV – QuickTime
    – Size: 94.06 MB
    – Duration: 23s 560ms
    – Bitrate: 32.0 Mbps
    *** Video Track Parameters ***
    – Format: DVCPRO (PAL)
    – Bitrate: Max.: — / Average: 24.4 Mbps / Min.: —
    – Frame rate (fps): Max.: — / Average: 25.000 / Min.: —
    – Encoding profile: Undefined
    – Image size: 720*576
    – Pixel Aspect Ratio: Undefined
    – Display Aspect Ratio: 295:162
    – Interlacing: Interlaced – Bottom Field First
    *** First Audio Track Parameters ***
    – Format: Uncompressed PCM
    – Bitrate: 768 Kbps
    – Resolution: 16 bits
    – Rate: 48.0 KHz
    – Channel(s): mono
    – Position: Front: C
    The setting I am using in FCPX are
    Video
    PAL SD 720*576 25i
    Audio
    48Khz Stereo
    I have 4 tracks of audio.
    Why does it render everytime I add anything? Cheers
    James Bayliss-smith replied 14 years, 9 months ago 2 Members · 2 Replies
  • Tom Wolsky
    January 2, 2012 at 12:33 pm
    The project needs to be set to PAL DV not uncompressed.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2012 “Complete Training for FCPX” from Class on Demand
    “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • James Bayliss-smith
    January 2, 2012 at 1:26 pm
    so
    PAL 720×576 DV Anamorphic
    as opposed to
    PAL 720×576 Anamorphic.
    DVCPro is classed as DV? I guess so?
    Cheers I’ll give it a whirl
