Activity Forums Maxon Cinema 4D Why does my hair spawn from black
  • Why does my hair spawn from black
    Posted by Doyle Lewis on November 12, 2014 at 6:37 pm
    So this is my first character sculpt and also my first BodyPaint texturing ever. I like how it turned out for the most part. I definitely learned a lot to do better next time but for my first I am satisfied. What I don’t like are the roots of his hair though. No matter what color the hair is or what color texture I put under it, the base that the hair sprouts from looks black.
    As you can see with the image above, I copied the polygons I wanted hair to grow out of so that they each had their own separate geometry from the head. I think this might be the source of my problem but I couldn’t get the hair material to apply to a polygon selection.
    I guess my question is two part. 1: what is causing the base polygons to render black and 2: what is the more effective way off applying hair to only part of your geometry.
    Doyle Lewis, Assistant Videographer
    thinkck.com
    Doyle Lewis replied 11 years, 10 months ago 2 Members · 2 Replies
  • Brian Jones
    November 13, 2014 at 12:42 am
    you can grow hair from a polygon selection – select the polys you want hair from and Add Hair or set a selection first and the hair will use it.
    To get the roots to not be dark go into the hair material Illumination tab and lower diffuse (to 0% even)
  • Doyle Lewis
    November 13, 2014 at 2:30 pm
    Thank you Brian! Now that I have stepped away from it for a bit I realize that I probably couldn’t do a poly selection because the head was still a sculpt object and I never baked out my final mesh. As for the roots that worked great! thanks!
    thinkck.com
