Activity Forums Adobe After Effects Why does my camera null move sometimes?
  • Why does my camera null move sometimes?
    Posted by Maha Mohtaseb on April 13, 2012 at 8:32 am
    Sometime the null that I’ve parented the camera to moves as I change its position, rotation, etc. I’m not sure why/how this is possible when my camera is parented to it. Any ideas on why this is happening?
    Thanks for reading.
    Maha
    Maha Mohtaseb replied 14 years, 5 months ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    April 13, 2012 at 11:57 am
    Hi Maha, it sounds like you’re not explaining yourself clearly of that there is some confusion as to how Parenting works. What you have described is expect behavior, ie moving a Parent layer and actually having it move.
    Upon creating a Parent/Child structure, changing Transform values for the Parent will affect the Parent as well as the Child Layer. You can however change the Child’s Transform values without affecting the Parent Layer.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Cassius Marques
    April 13, 2012 at 12:05 pm
    Roland… he meant he parented the camera to a null… and he is moving the null. It should stay put in the center of the screen;
    If that null has it’s 3d switched on. it maybe because the anchor of your camera is not at the null(perhaps a different z)…so rotations and scales would influence it differently? check for that…
    Edit: press “a” on the camera and check if you read 0,0,0.
    April 13, 2012 at 12:36 pm
    OR he could be viewing the comp in something other than the Active Camera view. Depending on the view mode and the property involved, what he’s describing is a very likely result.
    HTH
    RoRK
  • Maha Mohtaseb
    April 13, 2012 at 9:21 pm
    Thank you for that, Dave, this is definitely what’s going on. Interesting, I didn’t know such a thing existed, but makes perfect sense- too I often I just copy/paste key frames instead toggle holding. Good to know.
