Activity Forums Adobe Illustrator Why does illustrator cs5 template layer pick up colors from dimmed image
  • Why does illustrator cs5 template layer pick up colors from dimmed image
    Posted by Cyndi Wiley on September 6, 2011 at 6:54 pm
    Hello!
    I am having trouble with creating a template layer from which to trace over a JPG. I have created the template layer with the image, locked it and set the dim to 50%. However, when I use the eyedropper over the image to color the layer on top with gradient mesh, it picks up the dimmed color. Setting the template layer to 100% fixes the issue, but other computers in the lab work to do this technique with the 50% dimmed template.
    Any advice?
    Cyndi
    Cyndi Wiley replied 15 years ago 1 Member · 0 Replies
  • 0 Replies
