Activity Forums Apple Final Cut Pro Why does FCP X show two tracks of audio when I recorded one?
  • Why does FCP X show two tracks of audio when I recorded one?
    Posted by Noam Osband on October 14, 2015 at 4:16 pm
    Often, when I have a clip with just one track of audio, FCP X detects two tracks, the second of which has almost or completely no activity on it. Why does it do that? It means for all these clips I need to manually disable the empty one.
    John Rofrano replied 10 years, 10 months ago 3 Members · 2 Replies
  • Jeff Kirkland
    October 14, 2015 at 10:39 pm
    Almost no activity isn’t the same as being an empty track. I guess FCPX is just erring on the side of caution. I’m assuming here that you’ve asked it to remove empty tracks on import, which is something I rarely use. I find I’m better at picking empty tracks than FCPX.
    Ultimately, it’s no big deal to select the clip(s) in the browser and toggle the offending track off.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • John Rofrano
    October 17, 2015 at 2:29 pm
    If you recorded a stereo track with a mono microphone so that only the left channel has a signal, FCP X is probably still seeing it as the primary stereo pair. I agree with Jeff that any activity at all would make it not empty. I haven’t tested trying to get FCP X to remove a silent channel from a stereo pair because I always record on both tracks with one having the volume lower as a safety in case the main track over modulates. Like Jeff said, just turn it off in the clip properties.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
