Activity › Forums › Apple Final Cut Pro Legacy › Why does FCP set 30fps TC Rate for certain audio clips that lack TC stream?
  • Why does FCP set 30fps TC Rate for certain audio clips that lack TC stream?
    Posted by Matthew Griffin on May 4, 2008 at 1:06 pm
    Hello folks,
    I’m cutting a DVCPRO HD 720p50 feature at 25fps on FCS2 w fcp 6.0.3. (Used a PAL Panasonic HVX200)
    When I import certain of the audio files from the location sound recordist, FCP lists the file as having a TC Rate of 30fps — and puts a greenbar over my audio track in the 25fps timeline. the audio folks were not TC locked to the camera, so I’m in the midst of doing a manual post-sync (yeah, yeah) of all of these files and Merging them into new Master Clips (1V+6A) for editing.
    I already learned the great trick from this forum of importing the audio takes folders from each day and then disconnecting them to set them all as dual mono, then reimporting — makes my Merge clips work the way I had hoped they would.
    But this 30fps/25fps issue is really holding me up. This phenomena of tracks mysteriously being picked as having a TC Rate of 30 is rare, like 50 of the 400 audio files, but I can find no way within FCP to correct this setting nor any indication why these files were chosen.
    I can’t change the TC from 30-25 when a clip is online or offline — I get the message “The media of one or more selected clips does not support the chosen timecode rate of 25, and are left untouched.”
    Any help will be wildly appreciated — I am eager to complete this sync project and get cutting!
    matt
    Garrett Robinson replied 14 years, 10 months ago 6 Members · 12 Replies
  • 12 Replies
  • David Roth weiss
    May 4, 2008 at 4:14 pm
    Are you sure the audio was recorded at 48khz? Check one of the original files in the Quicktime player. Could it be at 44.1khz possibly?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Matthew Griffin
    May 4, 2008 at 6:43 pm
    Definitely 48k. Not sure what that would effect Timebase, but I am very happy to check anything you folks suggest!
    Some of the post-sync tracks are mono, some stereo — I cannot determine any logic by which it chooses which files should stick stubbornly to TC Rate of 30!
    I am tempted….with much back up….to change the TC Rate element by hand in the FCP Project files opening in BBEdit or similar. That is likely to be a bad idea, but if I can’t think of anything else, I’d rather do an annoying process 45 times by hand and know the issue is solved rather than keeping these 30fps Timebase audio files in Merges where they sound like they are drifting out of sync.
    Thanks for suggesting I check the sample rate. Other suggestions?
  • David Roth weiss
    May 4, 2008 at 6:45 pm
    Admittedly, I was reaching on that one… But, just trying to check all possibilities.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    May 4, 2008 at 7:38 pm
    [Matthew Griffin] “When I import certain of the audio files from the location sound recordist,”
    What kind of files and from what device?
  • Matthew Griffin
    May 4, 2008 at 11:49 pm
    ah. I’m afraid I don’t know what it was — I think the recording device is the Tascam compact flash recorder. In any case, it recorded .wav not broadcast wave files on a compact flash card, which the recordist delivered to me with as a folder each for the shoot days. There are xml files for markers.xml and settings.xml but in this specific case these things don’t matter because there was no smartslate or tc generated by camera.
    So these are just wave files — 48k 16bit — lacking any timebase. For some reason FCP has decided to give them a timebase instead of following the protocol of the project’s 25fps timebase. 90% of the files come through as TC Rate 25fps just fine. Those that are marked as 30fps are then out of sync with the audio tracks with picture because they are being falsely pulled down for 25fps.
    I’m basically hassling with this now so my sound team doesn’t have to hassle with it when I deliver these frustrating out of sync dialogue tracks cut into seq. Trying to get the world truly back to 25fps timebase family.
    Thanks for your curiosity! Does this help suggest a solution?
  • Bouke Vahl
    May 5, 2008 at 12:16 am
    Perhaps Spherico’s BWFtoXML tool can do something.
    Otherwise, it’s no hassle for me to write something to convert them into BWF. It’s just adding a bit to the header or footer of the file.
    (i’m already working on a QT to BWF tool)
    I could use the file creation time to insert that as TC, hoping there is ‘some’ relationship to the footage. (at least you know the order the clips are recorded…)
    Bouke
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • Jeremy Garchow
    May 5, 2008 at 12:17 am
    Hmm. how bout this?
    Choose a PAL easy setup (say DV PAL). then quit FCP.
    Now reopen FCP with a new project (not your current project).
    Reimport a couple of the ‘bad’ files. Do they come in @ 25 fps now?
  • Russell Lasson
    May 5, 2008 at 12:58 am
    I’m really confused by why the files would have a green render line when imported into a sequence. Can you open the files in QT and then get info on it, then tell us the exact specifics of the file type?
    Also, how bad is the sync issue? Does the audio come before the video or the other way around?
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Matthew Griffin
    May 5, 2008 at 12:30 pm
    I’ll be darned. going to a basic PAL Easy Setup and project worked! all files came in as 25fps with no problems, and I could make them dual mono and drag them into my main project without a problem.
    So thanks so much! I somehow got caught up trying to fix this darned document instead of dropping it and doing my work in a project file with no history — good idea going forward!
    Matt
  • Matthew Griffin
    May 5, 2008 at 12:36 pm
    Essentially, FCP believed the lognote that the audio was 30fps and performed a pulldown to play each cluster of samples more quickly so that the TC Rate would match 25fps. Unfortunately, this was an unnecessary compensation so the 30fps stuff (for long clips) finished slightly early on the longer takes (barely noticeable otherwise).
    At least I think so — I’ve just fixed this problem with the help of this thread and can’t check again to make sure.
    Anyhow, this action wasn’t native-to-seq-settings playback so there were green bars on the audio track suggesting to render them for best performance.
    I didn’t actually solve why this problem appeared, but the solution to import the audio and prep it in a vanilla PAL project worked perfectly!
    Matt
