Activity › Forums › Adobe After Effects › Why do Particular particles set to Bounce pass through floor?
  • Why do Particular particles set to Bounce pass through floor?
    Posted by Mike Mackenzie on July 18, 2014 at 5:36 pm
    https://www.dropbox.com/s/nx1s2ibw2uu3hqr/ACF_title%201.12.09%20PM.m4v
    This is what I’m working on. If you notice towards the end, there are some leaves that drop behind the “-ing” of “Consulting.” They should be stopped by the floor layer and be part of the ring pile, as the other leaves are, but are not. Floor layer is a solid with turbulent noise. Front view shows the floor is indeed below the Particular layer. My physics are Bounce, and the bounce event is stick.
    Any and all help appreciated!
    Mike Mackenzie replied 12 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
