why do gaps appear in my compound clip?
I have two similar projects, similar in structure, 1080p, 48KHz, etc.
I made a compound clip of each project by opening the project, selecting all clips, then File->New->Compound Clip.A funny thing happened. One compound clip was just fine, but when I opened the 2nd compound clip it had 1 frame gaps between each original clip. See pictures below.
First a section of the original timeline:
and what it looked like after I selected all, turned it into a new compound clip, then opened that compound clip:
As you can see, the gaps between the clips, aside from being unsightly, ruin the timing of both the video and the audio. This happens to only one of the 2 projects I tried it on. I can’t figure out what the missing variable is. Any ideas?
John F. Williams
