Activity › Forums › Apple Final Cut Pro › Why change audio from little-endian to big-endian?
  • Why change audio from little-endian to big-endian?
    Posted by Francois Stark on November 13, 2012 at 4:13 am
    Can somebody please explain:
    When I export Apple Prores HQ with 16 bit audio from FCP 7, I get little-endian audio.
    When I export Apple Prores HQ with 16 bit audio from FCP x, I get big-endian audio. There is no way to change the audio to little-endian on a FCP X system.
    I need to play these clips on a Blackmagic Hyperdeck, and it only plays little-endian audio.
    What do to?
    Regards
    Francois
    Jeremy Garchow replied 13 years, 10 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    November 13, 2012 at 4:35 am
    Compressor allows Little Endian.
    You’ll have to setup a custom Compressor setting, then in the FCPX Share window choose “Add Destination > Compressor Setting”.
    Jeremy
