Activity Forums Adobe After Effects Why can’t I see any shadows??
  • Why can’t I see any shadows??
    Posted by Del Frost on June 9, 2009 at 2:35 pm
    Okay, I’m sure the answer to this is simple but here’s the scenario:
    I’ve imported an AI file containing a 4 letter word. (No, not that one.) I’ve duplicated it 3 times & drawn a mask around a different letter in each dupe so that the 4 letters are separate.
    They’re all set to 3D.
    I’ve animated their motion through z so that they fly from behind the camera & land on a background solid.
    The background solid is also set to 3D.
    I have a camera & a parallel light which is set to cast shadows.
    All the layers are set to cast shadows but not to receive (except for the background solid, of course) & all the ambient light settings are at zero.
    So why can’t I see any shadows? I simply cannot spot the (presumably obvious) problem here.
    Can anyone help?
    Roland R. kahlenberg replied 17 years, 3 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    June 9, 2009 at 3:54 pm
    hehe – just kidding of course.
    I would switch to using a Spotlight which has a wider range. Also, oftentimes, the relative positions of your object, camera and background (shadow layer) have to be strategically placed.
    Oh, and ensure that Draft 3D isn’t switched on – well, it does happen. 🙂
    HTH
    RORK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
