Activity › Forums › Apple Final Cut Pro Legacy › Why can’t I get this matte key to work?
  • Why can’t I get this matte key to work?
    Posted by Gareth Randall on October 9, 2007 at 5:20 pm
    I’m trying to composite two clips using an animated matte. The matte itself was captured from tape in the same way as the two video clips, it wasn’t imported as a targa sequence or anything like that.
    The intended effect is to have Clip A wiped away by the matte to reveal Clip B – very simple you’d think. I’m familiar with using animated mattes in Avid and Premiere, but I just can’t get it to work in FCP. I can’t find a “track matte” option, so I’m trying to use the “image mask”, which according to the FCP manual will work with either single-frame masks or animated masks.
    I’ve put Clip A on V2, Clip B on V1. Then I added the Image Mask filter to Clip A, and dragged the matte clip into the little dropbox in the Image Mask control panel.
    I’d hoped that would be all the work necessary, but it
    Richard Harrington replied 18 years, 12 months ago 2 Members · 3 Replies
  • Richard Harrington
    October 9, 2007 at 5:21 pm
    Stacvk the clips and use your transfer modes aka blending modes… there is one in there for matte keys
  • Gareth Randall
    October 9, 2007 at 5:25 pm
    Wow, that’s what I call speedy service! =;-)
    So should I put Clip A on V3, the matte clip on V2 and Clip B on V1, or is it Avid-style, with the matte on V3, Clip A on V2 and Clip B on V1?
    And which clip(s) should I apply the “travelling matte” transfer mode to? Just the matte clip?
    October 10, 2007 at 12:34 am
    Just launch the help menu…. now that you know what its called…. it will go easy
