Activity Forums Apple Final Cut Pro Legacy Why can’t I capture the whole tape instead of clips
  • Why can’t I capture the whole tape instead of clips
    Posted by Danny on November 1, 2007 at 5:01 pm
    I’m capturing HDV 720p footage from a JVC H110 camera. I’ve un-checked the “make new clip on start and stop” in the log and capture menu. And I’ve chosen “On timecode break warn after capture” in the User Preferences.
    If I log the entire tape to be captured as one single clip I get an error message on capture that says there’s a problem in the stream. If I use capture now it will capture the entire tape, but it breaks it up into several clips.
    My goal is to capture the entire tape as one clip. What am I doing wrong?
    Danny
    Tom Deangelis replied 16 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
  • Danny
    November 1, 2007 at 5:03 pm
    for email notification only
  • Tom Wolsky
    November 1, 2007 at 5:12 pm
    I have only ever been able to capture this format as separate clips. It will not capture whole tapes as a single item, unless it’s been shot like that.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Paul Escandon
    November 2, 2007 at 5:41 am
    Your only other option is to set your vtr option as a non-controllable device, hit play on your deck/cam, and then hit capture now. It will capture the whole tape – the only problem is that it will problem lose timecode sync at some point. But if you’re okay with that – that is an option.
  • Danny
    November 2, 2007 at 10:22 pm
    Thanks for the great idea!
    Danny
  • Danny
    November 2, 2007 at 10:24 pm
    Thanks Tom! I guess I’ll live with it 🙂
    Danny
  • Nick Price
    November 3, 2007 at 7:23 pm
    also if the timecode is continous on the tape, you can add it after in the modify menu/timecode. Pick a cut on the tape so you know the exact timecode at that point and type it in, viola, one long clip with timecode
    nick
  • Tom Deangelis
    November 3, 2009 at 1:08 pm
    Does anyone have a real solution?
    I’m trying to capture extended clips in order to make full use of the multi-clip editing feature in FCP.
    It’s bad enough getting “timecode break” messages and having to match frame edits from a single cam, but when I’m trying to cut long shows using 2 or more synced cams; these timecode breaks are a disaster.
    I’m trying to capture 1080i HDV from a Sony HVR-M25u feed deck. I’m ingesting this down an HDMI cable thru a Matrox MX02 box.
    The drive is a 1TB G-Raid
    The MAC is a 2 x3 GHz quad core with 4 gig of ram and we’re running the Snow Leopard OS
    I thought initally this issue was an HDV capture issue and/or a Matrox throughput issue, but I and my colleagues are having the same problems capturing SD simple 720×486 DVcam down a simple firewire connection.
    I’ve even tried rs 422 control taking in component video from a UVW1800 Betacam Sp deck…….still getting timecode breaks.
    Anyone having any luck solving this or is this just an FCP bug that we need to wait for Apple to address?
