Activity › Forums › Adobe Premiere Pro › Why can’t I add audio tracks to Audio1-Audio4?
Posted by Sum Choi on December 22, 2012 at 8:46 pmI’m completely new to Adobe Premiere. Can anybody tell me why I can’t drag add audio clips to Audio1-Audio4? I am coming from FCP7 and when I try to drag A1 to Audio1-Audio4, nothing happens.
Gabriel Sanchez replied 13 years, 8 months ago 5 Members · 5 Replies -
Stefan Kamp
December 22, 2012 at 10:50 pmMake sure you try to edit MONO sound in MONO tracks,and stereo in to stereo tracks
FCP ,Ppro ,MC, Lightworks
Ann Bens
December 23, 2012 at 11:34 amIn CS6 you can drop mono and stereo in the same track.
Can you drop audio in track 5.
Or can’t you drop audio at all or just these kind of files.
Be more specific.
What kind of audio are these files?———————————————–
Adobe Certified Expert Premiere Pro CS6
Adobe Community Professional -
Jeff Pulera
December 23, 2012 at 6:17 pmAudio tracks by default are usually 48k, so if for instance you have an audio clip at 44k, it won’t drop into a 48k track. Drag clip from bin down to very bottom of sequence and it will create a new audio track to match your clip. If you want to clean up the work area and get rid of empty audio tracks, right-click on left area of audio track, choose “Delete Tracks” and then “Delete empty tracks”
Jeff Pulera
Safe Harbor Computers -
Ann Bens
December 24, 2012 at 12:14 amI have no trouble dropping an audio file with 44.100 sample rate in a 48000 track.
