Why are they different
Posted by Travis Radke on May 19, 2020 at 1:19 amI have two video clips that dont sound different and both were recorded on obswith the same equipment and settings. but one clip shows spikes in the audio where the other is a flat line. I don’t know if this is a problem with OBS or Vegas Pro, can you guys help? The flatline is inconvenient when editing and I dont know whats causing it.
Mark Barton replied 6 years, 3 months ago 3 Members · 12 Replies -
Francois Pénzes
May 19, 2020 at 2:56 pmHi Travis
Can you post Mediainfo on each files ?
Cheers !
PC Win 10 Pro 64-bit 16gb
Ryzen 9 3900X 12 Core 4.60GHz
Radeon RX 5700 XT
Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
Vegas Pro 16, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Francois Pénzes
May 19, 2020 at 6:55 pmHi Travis
We need to know how the files are internally structured. A picture won’t do that. Download this (very useful) little software :
https://mediaarea.net/en/MediaInfo/Download
The resulting text file should look something like this, once to have analyzed it with Mediainfo:
It will give us all the details of your files.
Cheers !
Radeon RX 5700 XT
Travis Radke
May 19, 2020 at 7:51 pmMiss understand the first time. I’ll get back to you soon. Thank you.
Travis Radke
May 19, 2020 at 10:56 pmThis is the one that is flatlining
General
Complete name : D:\videos\TravtayPlays\Twilight Princess\part 2ish.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 1.43 GiB
Duration : 1 h 17 min
Overall bit rate mode : Constant
Overall bit rate : 2 643 kb/s
Writing application : Lavf58.12.100Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.2
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Constant
Bit rate : 2 500 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 60.000 FPS
Minimum frame rate : 58.824 FPS
Maximum frame rate : 62.500 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.020
Stream size : 1.36 GiB (95%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.470 System B/G
Codec configuration box : avcCAudio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate : 129 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 71.4 MiB (5%)
Default : Yes
Alternate group : 1This one is showing accurate spikes in the audio
General
Complete name : D:\videos\TravtayPlays\Twilight Princess\let’s play\our tp exp1.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42)
File size : 675 MiB
Duration : 11 min 19 s
Overall bit rate mode : Variable
Overall bit rate : 8 336 kb/s
Encoded date : UTC 2020-05-15 19:21:07
Tagged date : UTC 2020-05-15 19:21:07Video
Format : AVC
Format profile : Main@L3.2
Format settings : CABAC / 3 Ref Frames
Format settings, Reference frames : 3 frames
Format settings, GOP : M=4, N=15
Codec ID : avc1
Bit rate mode : Variable
Bit rate : 8 142 kb/s
Maximum bit rate : 16.0 Mb/s
Width : 1 280 pixels
Height : 720 pixels
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.295
Stream size : 659 MiB (98%)
Language : English
Encoded date : UTC 2020-05-15 19:21:08
Tagged date : UTC 2020-05-15 19:21:08
Format : AAC LC
Bit rate : 192 kb/s
Maximum bit rate : 318 kb/s
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Stream size : 15.3 MiB (2%)
Language : English
Tagged date : UTC 2020-05-15 19:21:07 -
Francois Pénzes
May 20, 2020 at 12:14 amHi Travis
Just got your Mediainfo. I’ve got some video packaging to attend right now but I quickly glanced at it and it looks like both of them were recorded with different specs.
I would like to know, if OBS was used to record each of them, why not with the same settings ?Cheers !
Radeon RX 5700 XT
Travis Radke
May 20, 2020 at 1:04 amThat’s strange because they were recorded only a couple days apart and within that time I’m pretty sure I didn’t change the settings.
Francois Pénzes
May 20, 2020 at 12:03 pmHi Travis
For now, lets try something… Make sure that only the ”flatline” audio track is selected. Right click on the track and go to Properties. Check box Normalize. Let me know what happens.
Cheers !
Radeon RX 5700 XT
Travis Radke
May 20, 2020 at 7:19 pmThat worked. Thank you. I still don’t know why my recordings are coming out flatlined but this will help with all my future editing. Thanks again.
Travis Radke
May 20, 2020 at 7:22 pmI’ve noticed that a lot of my renders come out very quiet but normalizing them boost the audio up significantly as well so I think you’ve managed to fix two things.
