Francois Pénzes
May 20, 2020 at 8:54 pmHi Travis
Glade to know it worked out. Keep the recording settings for the one that worked the first time for next you record with OBS.
Cheers !
PC Win 10 Pro 64-bit 16gb
Ryzen 9 3900X 12 Core 4.60GHz
Radeon RX 5700 XT
Cameras: Canon XF305 + Canon XH-A1 and a bunch of others
Vegas Pro 16, User since Vegas 3.0\’\’When the cutting stops, the editing begins…\’\’
Mark Barton
May 23, 2020 at 7:00 pmCheck your audio source in OBS. It sounds like you have a microphone input rather than the audio source you intended. If you are trying to capture system sound, you might be catching it at a low volume from a built-in microphone that is picking up the speakers. When you normalize a flat line audio signal, it will boost it, but could be adding a lot of noise and distortion you do not want. If you use bluetooth audio sources, these can sometimes change the OBS settings depending on whether they are connected at the time OBS starts up.
