Activity Forums Adobe After Effects Why are my different res QT MPEG4 files the same file size!??
  • Why are my different res QT MPEG4 files the same file size!??
    Posted by Gizmo1990 on January 31, 2006 at 7:37 pm
    When I render out a 10 sec clip using Quicktime/MPEG4 compression at 720X576 and 320X240 both the resulting files are the same size!?
    Why is this!?
    Any help appreciated.
    Gizmo1990 replied 20 years, 7 months ago 2 Members · 4 Replies
  • Alexander Gao
    January 31, 2006 at 8:50 pm
    maybe you are using a set bitrate? I honestly dont know any better, but thats just an idea.
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
  • Gizmo1990
    January 31, 2006 at 9:01 pm
    Thanks for the reply.
    Yes I am using a set (400) bitrate… but why should that mean the sizes would be the same? Ones less then half the res as the other?
  • Alexander Gao
    January 31, 2006 at 9:21 pm
    this matters because the bitrate is on a per-second basis, and that means you’re getting the same amount of bits per second in both of the videos (basically, you are just cramming more info into the smaller one that is not needed.)
    Alexander Gao
  • Gizmo1990
    January 31, 2006 at 10:12 pm
    Aha! Thank you I never knew that!
    Now it makes sense. 🙂
