Activity Forums Adobe After Effects Expressions Why are Extendscript objects invalidated when created inside functions?
  • Why are Extendscript objects invalidated when created inside functions?
    Posted by Carey Pagan on March 16, 2021 at 10:02 pm
    2
    function addControl(layer, name){
        newCtrl = layer("Effects").addProperty("Slider Control");
        newCtrl.name = name;
        return newCtrl;
    var Slider1 = addControl(ExistingLayer, "slider 1");
    $.write(Slider1.name);
    var Slider2 = addControl(ExistingLayer, "slider 2");
    Error Code# 45: Object is invalid
    Attempting to access Slider1.name after Slider2 is created results in an error as Slider1 is now [Invalid Object]
    I feel this has something to do with referencing and garbage collection but as javascript objects should pass as reference and 'addProperty' should create a new object, I don't understand why.
    I should add it fails with and without the 'var' keyword
    Carey Pagan replied 5 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
