Activity › Forums › Adobe Premiere Pro › Why am i getting 720p despite my video is 1080p?
Posted by Engin Osmanovski on February 20, 2013 at 5:01 pmDespite i rendered my video as H264 HD 1080p, when i upload it to Youtube the maximum quality option under the video seems to be 720p. What might i be doing wrong?
I chose “Scale to Fill” option in the Output tab of the Export Settings window. Can this be the reason? (The size was still set to 1080p…)
Chris Borjis replied 13 years, 7 months ago 5 Members · 7 Replies -
Chris Borjis
February 20, 2013 at 5:03 pmopen the encoded file you uploaded to youtube on your system…is it 1080?
Engin Osmanovski
February 20, 2013 at 5:23 pmYes, it is, Chris.
Actually the problem seems to be solved right now. I don’t know how but 10-15 minutes after the upload the maximum quality option became 1080p as it should be. I have no idea why it was 720p before.
Kris Merkel
February 20, 2013 at 5:24 pmI believe that YouTube upload requirements are 720p . I could be wrong but we always compress for 720p for you tube delivery no matter what the HD source
“Think of everything in terms of building capacity.”
Kris Merkel
twitter: @kris_merkel
Product Manager, Flanders Scientific Inc.
http://www.shopfsi.com
Co-Founder, Atlanta Cutters Post Production User Group
http://www.atlantacutters.com2.2Ghz MBP core i7
16Gb RAM
CS6/FCP7
AJA T-Tap
AJA IO XT
FSI LM-2461W/CM-170W -
Engin Osmanovski
February 20, 2013 at 5:27 pmBut why is there a 1080p Youtube preset in Premiere Pro if youtube requirements are 720p?
Tom Daigon
February 20, 2013 at 6:13 pmEverything I upload to You Tube is 1080P. There is a slight delay after uploading that involves the processing of that video. Over a few minutes the 1080 display option is eventually displayed.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=DxPrG3WUyz8
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
Chris Tompkins
February 20, 2013 at 8:45 pm -
Chris Borjis
February 21, 2013 at 5:14 pmshould be noted the Vimeo specs are about the same but they
recommend:2,500 kbps for SD video
5,000 kbps for HD video
Stick to those for Vimeo as they stream the exact file you upload,
any higher and it will likely stutter on lower end systems.
