Activity › Forums › Adobe After Effects › Whould this be OK for AE?
Posted by David Fekete on March 8, 2008 at 1:54 pmhey
I want to buy a notebook.Would a 1.8 coreduo and a go7300 be enough for AfterEffects or is it worth of paying 60$ extra to get a 2GHz coreduo? Is it that faster? Is there a big difference? would the gpu be enough? or do ATI cards work with AE? Does go7300 support HD play?Darby Edelen replied 18 years, 6 months ago 3 Members · 4 Replies -
Randy Mcwilson
March 9, 2008 at 2:33 amI have a 2Ghz core2duo T7200 in my laptop with 2 GB of ram and a mobile radeon x1600. I could not ask for better AE performance in a laptop. While not a screamer, I can run AE, PPro, and IE all at the same time with acceptable results.
I just wish they would release quad core laptop processors (like the q6600).Eternity…don’t miss it for the world.
Darby Edelen
March 9, 2008 at 6:14 am[David Fekete] “Would a 1.8 coreduo and a go7300 be enough for AfterEffects or is it worth of paying 60$ extra to get a 2GHz coreduo? Is it that faster? Is there a big difference? would the gpu be enough? or do ATI cards work with AE? Does go7300 support HD play?”
Don’t worry about the GPU at all for AE. Literally, not at all. Get the cheapest GPU you can that will do everything else you need it to do (3D programs? Fancy OS animations? etc). Get as much RAM as you can and get the best processor you can reasonably afford.
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
David Fekete
March 9, 2008 at 4:07 pmI see.Though I still dont get the difference between a 2ghz coreduo and a 1.7 core2duo.which is better?
Darby Edelen
March 10, 2008 at 3:39 am[David Fekete] “Though I still dont get the difference between a 2ghz coreduo and a 1.7 core2duo.which is better?”
In general terms, a faster clock speed is better, so 2GHz > 1.7GHz, although this doesn’t apply as much when comparing processors from different manufacturers/using different architectures (A 1.8GHz Celeron for example wouldn’t be as good as a 1.7GHz Core 2 Duo).
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA
