Activity Forums Blackmagic Design Whites clipping in Deck control when using “Grab Frame”
  • Whites clipping in Deck control when using “Grab Frame”
    Posted by Chris Oben on March 14, 2007 at 12:17 am
    I am using Deck Control to grab frames from a live 1080 source. (Sony F900/3). I am using easy setup ‘Blackmagic HDTV 108023.98 – 8bit’. When I output via Photoshop ‘Blackmagic Image Export’. The images’ white (highlight) information is always clipped above 100ire (700mv). Is this due to a limitation in the capture codec? Or a colur space conversion limitation? When i capture a quicktime movie using the same 8 bit Easy Setup – there is no clipping. Why do the still images clip?
    Chris M. Oben
    http://www.chrisoben.com
    Chris Oben replied 19 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
