Activity Forums Sony Cameras White vs. Warm Balancing
  • White vs. Warm Balancing
    Posted by Oliver De morassé on June 27, 2013 at 1:54 pm
    I use a Sony PMW-200. I thought about purchasing a good quality 18% gray card for my white balancing. However, I was also recommended to try the Vortex Media WarmCards 3.0 instead. I film mainly indoors in a green screen studio. However, we also do shoots outside (sunny bright skies, snow glare). Any suggestions & recommendations?
    Thanks, Oliver
    Oliver De morassé replied 13 years, 2 months ago 3 Members · 4 Replies
  • Bob Mark
    June 29, 2013 at 7:34 pm
    You should balance to a white card, not gray. The warm cards are to cheat the camera toward red (warm) by removing some blue in the picture. You can do this in your camera profiles, too by adjusting the color matrix. This might be helpful.
    https://www.rexfilm.hu/documents/document/document/3261/Picture_Profile_settings_in_the_PMW-200.pdf
    Bob
  • John Sharaf
    June 29, 2013 at 7:50 pm
    Nothing wrong with using a true gray card for white balance. the process merely requires a target that is devoid of color! An advantage of gray might be that it’s probably less susceptible of reflecting another strong color in front of it?
    For your green screen shoots, if lighting with tungsten balanced photo quality lights, preset 3200 is a good choice.
    I always recommend flipping back and forth between preset and the AWB while observing on a properly adjusted monitor and choosing the best look. It might be counter intuitive but still correct.
    JS
    JS
  • Bob Mark
    June 30, 2013 at 3:19 pm
    Here’s a run down on what Vortex Media cards offer.
    https://www.warmcards.com/WARMCARDS_USERGUIDE_V3.pdf
    Take a look at page 6 to see how each card effects the white balance.
    For another option you can use a Rosco Jungle Book to manual white balance.
    Bob
  • Oliver De morassé
    July 4, 2013 at 1:54 pm
    Thanks for all your feedback.
    I have decided to try out the WarmCards 3.0 (also included a pure white and grey card). Will let you know what my test results are.
    Thanks again
