Activity › Forums › Adobe After Effects › White foamy mustache of a boat wake …Form…
Posted by Niccolò Ungaro on August 25, 2011 at 7:30 pmHow can I get a wash track of foam that follows a boat path …..?
Thank you all for your kind attention.
Nic.Niccolò Ungaro replied 15 years ago 2 Members · 7 Replies -
Tudor “ted” jelescu
August 25, 2011 at 8:24 pmAre you referring to something like this:
https://www.youtube.com/watch?v=sbV45M_qOeA
?Tudor “Ted” Jelescu
Senior VFX ArtistSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Niccolò Ungaro
August 25, 2011 at 8:24 pm -
Niccolò Ungaro
August 25, 2011 at 8:27 pmYes..!
Somthing like that…with more foam…
I wisch i could find som fractal nois preset… Or even better R.G. Form…preset or tutor…. -
Tudor “ted” jelescu
August 25, 2011 at 8:34 pmI did that using FreeForm Pro, but you can use the regular Free Form that comes with AE as well. The trick is to have a nice animated texture of water splashing (I used Particle illusion to create that)with a feathered alpha. Then you need to match the angle of the perspective and add some fractal texture on a 3d layer with a mask for extra foam in the water.
Tudor “Ted” Jelescu
Senior VFX Artist -
Niccolò Ungaro
August 25, 2011 at 8:41 pmGrazie Ted,
I know that you are a magician with Free Form.
You Advanced 2.5D Animation in AE tutor is very nice & challenging.
I will give a try to your anwer.
Thanks.
Nic. -
Tudor “ted” jelescu
August 25, 2011 at 8:51 pmGlad to hear that the stuff I put out there helps!
One other thing I did was to use Particular to create the foam around the tip of the warship in the clip below. I wish I had more time to play with it though.https://www.youtube.com/watch?v=9H_tG5_DV5Q
Tudor “Ted” Jelescu
Niccolò Ungaro
August 26, 2011 at 1:15 amNice very well dun thanks to share…although the sobject is not really my cup of tea.
