Activity › Forums › Adobe Premiere Pro › Whip Transitions advice
  • Whip Transitions advice
    Posted by Jeremy Ramos on April 6, 2016 at 9:15 am
    So I will be making a long take short film and in order to do that I need to use whip transitions for hiding cuts. How does one achieve the same quality of whip transitions like Birdman?
    https://youtu.be/FthEJGR61c8?t=3m35s
    The whip transition in Birdman is quite slow but it still manages to have enough motion blur to hide the cut. I’ve tried doing the whip transition with a pan that was slow enough to create some motion blur with a low shutter speed, but editing it was difficult. It was clear that there was a cut because you could see it, it would jump to the next clip. I want it to be a smooth transition, making it believable that there was no cut at all.
    So in summary, Birdman’s whip transitions are believable that there was no cut, how can I get the same quality?
    Usually when people do whip transitions they pan the camera really fast, I do not wish to do that.
    Jeremy Ramos replied 10 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
