Activity Forums Blackmagic Design Which workflow for jvc 700 mpg file with blackmagic card
  • Which workflow for jvc 700 mpg file with blackmagic card
    Posted by Mandeep Singh on August 16, 2010 at 11:30 am
    I have asked it quiet a times no answer. I copy files from jvc 700 sdcard . Now i want to know do i need to convert these files into uncompressed ones , if yes then how, and if not, then does that mean if i use blackmagic preset as sequence setting in premiere , i just import those mpg files which are considered to be compressed as they are directly from the camera . In the capture process i usually used 4:2:2 capture but here there is no capture so what is correct work flow of this one
    Mandeep Singh replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
