Activity Forums Apple Final Cut Pro Legacy Which WD Hard Drive?
  • Which WD Hard Drive?
    Posted by Bob Tanner on August 5, 2009 at 7:01 am
    I’m looking into buying two Western Digital Hard Drives each 1 TB, one which I will use solely for time machine and the second for final cut, I have 3 options, WD Caviar Black, WD Caviar Green and WD Caviar Blue. Has anyone had any good/bad experiences with any of them?
    Zevie
    Edit: I just saw on the Apple forums that the WD 640 Caviar Black 6401AALS…..: Media scratch disk WD 1.0 Caviar Green 10EADS………: Back up Time Machine
    Can anyone tell me if this is true?
    Neil Sadwelkar replied 17 years, 1 month ago 2 Members · 5 Replies
  • Neil Sadwelkar
    August 5, 2009 at 11:22 am
    Black are the fastest. They go up to 1 Tb.
    Green takes the least power and has variable rpm. They go up to 2 Tb
    I’ve used both and found them to be great.
    Blue are good performance but go up to 750 Gb.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Bob Tanner
    August 5, 2009 at 11:24 am
    Thanks, and it shouldn’t any problem to buy one black and one green and put it in the same mac pro, correct?
  • Neil Sadwelkar
    August 5, 2009 at 2:09 pm
    Ummm. Not really. But why would you want to do that?
    Neil Sadwelkar
    twitter: fcpguru
    Mumbai India
  • Bob Tanner
    August 5, 2009 at 2:14 pm
    Just curious, I guess I’m going to go with the Caviar Black. I’m just wondering how WD can have 3 different versions of internal HD where each one boast stronger features than the other. Take the Caviar Blue for example, “With SATA and PATA interfaces, cache sizes ranging from 2 MB to 16 MB, WD Caviar Blue drives offer a full range of performance features. Pick the drive that suits your needs with the confidence in knowing that all WD Caviar Blue drives are built to the highest standards of quality and reliability. ”
    Would that imply, that if I were to get the Caviar Black, its not the most reliable hard drive they make?
  • Neil Sadwelkar
    August 7, 2009 at 3:59 pm
    I think its Blue at the low end and if you need PATA.
    Green at the high capacity, but low power segment. These are variable rpm, so I’m not sure how that affects editing video.
    If you need rock-solid reliability, and don’t mind paying for it, consider Enterprise drives.
    Neil Sadwelkar
    twitter: fcpguru
    Mumbai India
