Activity › Forums › Blackmagic Design › which slot to install BM HD extreme?
  • which slot to install BM HD extreme?
    Posted by Paul Nevison on November 2, 2007 at 12:00 pm
    Hey just installing a new Decklink HD extreme card in a new Macpro quad 3ghz
    which slot should the card go in? Graphics card is in slot 1 and the other three are currently empty.
    eventually a FC card will need to go in to connect to an Xsan, but that’s not for a couple of months and am using local FW800 storage for now.
    any suggested slots? and does this even matter anymore (in the days of Cinewave slot management did make a difference)
    thanks
    Dan Sparks replied 18 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Dan Sparks
    November 2, 2007 at 5:29 pm
    Slot #4.
    Dan Sparks
    Tricom Video
  • Paul Nevison
    November 4, 2007 at 9:02 am
    thanks Dan,
    it seems BM haven’t updated their support docs in quite a while, so my next question is which driver should i go with in the following system, 6.6 or 6.1?
    MacPro 3ghz quad
    FCS 2 (FCP 6.0.1)
    10.4.10
    CS3
    thanks
  • Dan Sparks
    November 4, 2007 at 6:37 pm
    Currently I’m running the 6.5.1 driver. I’m in the middle of projects so I don’t want to update to 6.6 yet. When I finish up these shows I’ll probably load the 6.6 driver.
  • Paul Nevison
    November 4, 2007 at 10:10 pm
    thanks Dan,
    one other thing is the breakout cable on your Decklink HD extreme ridiculously short? on my previous Decklink SD card it came with a long breakout cable. This one is so short it’s virtually useless!
    thanks
  • Dan Sparks
    November 4, 2007 at 11:45 pm
    Yes my cable is the short one, too. I guess they save a few bucks giving us the short cable. I had to pick up a few new audio and video cables to complete my system wiring. I’ve been happy with mine and support has been there when I had questions.
    Good luck!
  • Ben Scott
    November 7, 2007 at 9:04 pm
    was wondering what card slot would you suggest on a PCI-x G5 as I also have documentation for my PCI-x slot Seritek firmtek 4 port esata card saying it wants to be in slot 4 which is the 133mhz slot
    also heard it can be difficult getting some blackmagic cards to fit this slot
  • Dan Sparks
    November 8, 2007 at 12:35 am
    Ben,
    I don’t have that same setup but here’s the info from the BMD site.
    https://www.blackmagic-design.com/support/detail.asp?techID=60#ppc_tiger
    Dan Sparks
    Tricom Video
