Activity Forums DSLR Video Which setup is best? 5D II or 5D III?
  • Which setup is best? 5D II or 5D III?
    Posted by Jeff Lester on May 26, 2012 at 6:06 am
    So, I’m planning on either buying a completely new video setup this summer (well, after the summer once I have earned the money that I need), and I can’t decide whether to buy a 5D II or III. I might even keep my GH2.
    But basically, I cannot afford to spend more than $10,000 (I’d like to spend way, way less actually). If I get the 5D III, I need to sacrifice the L series glass that I was going to buy for the camera and get medium quality Canon lenses. If I get the Mark II, I’d be getting three L lenses instead of just one.
    Here’s my theoretical setup for the Mark II and III – which do you think would be the better choice?
    Version 1 (for use with 5DII)
    Canon 5D Mark II (used) – $1,750
    5D Mark II Battery Grip – $100
    Z-Finder Pro 2.5x – $375
    5D Battery – $60
    SanDisk Extreme Pro 64GB CF – $329
    Pelican 1400 Case for 5DII – $72
    Canon 24-70mm f/2.8L (used) – $1,300
    Canon 50mm f/1.2L (used) – $1,325
    Canon 85mm f/1.2L (used) – $1,600
    Pelican 1510 – $165
    (x2) B+W 72mm UV Haze Filter for Canon 85mm, 50mm – $100
    B+W 77mm UV Haze Filter for Canon 24-70mm – $70
    Filter Pouch – $10
    Davis & Sanford Provista 7518 Tripod – $190
    Ikan VH7e 7” Monitor – $370
    Sony L-Series Battery – $105
    Ikan Mini-HDMI-HDMI Cable – $25
    Sunhood for VH7e – $25
    Konova Slider w/ Manfrotto 701HDV – $527
    500GB HD – $80
    (x6) Manfrotto 357 Pro QRs – $300
    Gini Rig w/ iFocus – $600
    Lighting – $500
    Miscellaneous DIY Stuff – $100
    TOTAL: $10,078
    Version 2 (for use with 5DIII)
    Canon 5D Mark III – $3,300
    5D Mark III Battery Grip – $350
    Z-Finder Pro 2.5x (for 3.2” screens) – $400
    5D Battery – $60
    Pelican 1400 Case for 5DIII – $72
    Canon 50mm f/1.4 (used) – $330
    50mm Lens Hood- $17
    Canon 85mm f/1.8 (used) – $350
    85mm Lens Hood – $15
    Pelican 1510 – $165
    (x2) B+W 58mm UV Haze Filter for Canon 50mm and 85mm – $54
    Filter Pouch – $10
    500GB HD – $80
    Lighting – $500
    TOTAL: $9,644
    Member of iFrosh
    Jeff Lester replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
