Activity › Forums › VEGAS Pro › Which render template in Vegas 13 Pro is closest to this? or can I replicate exactly? Thank you.
  • Which render template in Vegas 13 Pro is closest to this? or can I replicate exactly? Thank you.
    Posted by Amanda Duffield on November 3, 2016 at 2:48 am
    I’ve imported a video that has these settings:
    Format : Windows Media
    File size : 21.9 MiB
    Duration : 4mn 5s
    Overall bit rate mode : Variable
    Overall bit rate : 748 Kbps
    Maximum Overall bit rate : 1 109 Kbps
    Encoded date : UTC 2016-10-31 09:50:25.486
    Video
    Format : VC-1
    Format profile : MP@ML
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Description of the codec : Windows Media Video 9
    Bit rate mode : Variable
    Bit rate : 388 Kbps
    Width : 640 pixels
    Height : 484 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Variable
    Nominal frame rate : 10.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Language : English (AU)
    Audio
    Format : WMA
    Format version : Version 2
    Codec ID : 161
    Codec ID/Info : Windows Media Audio
    Description of the codec : Windows Media Audio 9.2 – 320 kbps, 44 kHz, stereo (A/V) 1-pass CBR
    Duration : 4mn 5s
    Bit rate mode : Constant
    Bit rate : 320 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Stream size : 9.36 MiB (43%)
    I’ve added some titles and text over the top and now would like to re-render it in Vegas 13 Pro.
    When I drop the footage into Vegas it asks ‘do I want to keep the same settings’ (or something similar) and I choose ‘yes’.
    Then, when I render I try to choose ‘match project settings’ however it says it cannot do that.
    So, I then tried to manually make my own template using these settings however i wasn’t successful.
    Can anyone tell me which render template in Vegas 13 Pro is closest to this or, how I can make my own using these settings? I’m wondering if some things are labelled differently, I couldn’t replicate exactly.
    Actually, I just have to get this footage @ 50mb or less and still have the titles and text crisp and clear. This is actually my main concern – I don’t really mind what format it is as long as it’s ‘generic’, clear, and useable for downloading and then playing on teachers’ own computers/electronic-whiteboards.
    Once I’ve added the titles and rendered – I’m choosing the wmv options however they’re all rendering way too large.
    THanks.
    John Rofrano replied 9 years, 10 months ago 5 Members · 6 Replies
  • Francois Pénzes
    November 3, 2016 at 9:13 am
    Hi Amanda
    Anyway that you can post a screen capture of your Vegas render settings ?
    Cheers !
    PC Win 7 64-bit 16gb * Intel® Core™i7-2600k Quad Core 3.40GHz NVIDIA GEFORCE GTX 550 Ti
    Cameras: Canon XF305 + Canon XH-A1
    \’\’When the cutting stops, the editing begins…\’\’
  • John Norton
    November 3, 2016 at 12:19 pm
    I assume u have already tried in render as .. tried selecting the = equals option?
  • Amanda Duffield
    November 4, 2016 at 12:23 am
    thanks. yes, I get an error message – something along the lines of ‘cannot match…’.
    Not at that machine work location today but will confirm when I can.
  • Amanda Duffield
    November 4, 2016 at 12:24 am
    thank you . yes. i will do that when back at that machine/workplace
  • Mark Barton
    November 4, 2016 at 2:07 pm
    You may need to take these larger Vegas renders and then use something like HandBrake to get to your final result. HandBrake has more options to match your final specs.
  • John Rofrano
    November 5, 2016 at 2:07 pm
    [Amanda Duffield] “Can anyone tell me which render template in Vegas 13 Pro is closest to this or, how I can make my own using these settings? I’m wondering if some things are labelled differently, I couldn’t replicate exactly.”
    Hi Amanda, You will need to create a custom template. To do this go to File | Render As… and under Windows Media Video V11 (*.wmv) select the 512 Kbps Video template as a starting point and press the Customize Template… button.
    Then make the following changes assuming your project is correctly set to 640×484:
    On the Video tab change:
    • Mode: Bit rate VBR
    • Format: Windows Media Video 9
    • Image size: (Keep Original Size)
    • Frame rate (fps): 10.000
    • Average bit rate (bps): 388 K
    Give the Template a new name and press Save to save it to your list. This should give you the original video specs.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
