Activity Forums Adobe Premiere Pro Which Presets you advise me to use for my project
  • Which Presets you advise me to use for my project
    Posted by Mohamed Gadallah on October 16, 2010 at 1:43 am
    Hello
    Please I am importing my video file into Adobe Premiere CS4.
    The video is PAL
    Now when I start any new project the Adobe Premiere CS4 asking me for which preset I should use from the following screen:-
    Please I am a bit confused about which preset I should use.
    Please advise
    When Excellence Becomes a Habbit
    Enjoy with respect
    Mohamed
    Andrew Devis replied 15 years, 10 months ago 3 Members · 4 Replies
  • Andrew Devis
    October 18, 2010 at 7:52 am
    If you look in the pp basics tutorials you will find a tutorial i did on understanding the splash screens. This will explain them all for you. Andrew
  • Mohamed Gadallah
    October 18, 2010 at 8:44 pm
    Please any links as the website is really let me feel lost.
    Enjoy with respect
    Mohamed
  • Vincent Rosati
    October 18, 2010 at 10:47 pm
    Determine your intended output.
    Are you going to make a DVD?
    If so, use a ‘DV – Pal’ preset.
    The i50 means Interlaced 50 Fields Per Second.
    If your footage is Interlaced PAL, then it is i50 (or 50i)
    i60 is NTSC, probably not for you.
    If your project is progressive, or not interlaced, you might use a setting like 25p.
    Is it going to be for some other format, web maybe?
    Regarding the codec…
    What is the codec and format/frame size/frame rate of your source material?
    If you’re not sure of the specs of your footage, try opening the footage with gspot.
    Just some thoughts to help get you started.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Andrew Devis
    October 20, 2010 at 12:11 pm
    https://library.creativecow.net/devis_andrew/Premiere-Pro-Starting-Splash-Screens/1
    this is the link, sorry it took a while to send it. The key is that the setting for the sequence should match the footage that comes out of your camera and not be set up for your output – that comes at the output stage. Hope you find this helpful. Andrew
