Activity Forums Apple Final Cut Pro Legacy Which MBP is better?
  • Which MBP is better?
    Posted by Aj Reuter on February 27, 2011 at 3:30 pm
    Macbook Pro
    13-inch: 2.3 GHz
    * 2.3GHz dual-core
    Intel Core i5
    * 4GB 1333MHz
    * 320GB 5400-rpm1
    * Intel HD Graphics 3000
    * Built-in battery (7 hours)2
    Macbook Pro 2.4ghz
    Core 2 Duo
    13 inch
    256 mb Nvidia graphics
    250gb hdd
    4gb ddr3 ram
    Thanks! I just bought the first one, but then the 2nd one came out. I can give this one back to apple for the 2nd so im trying to figure out if i should or not
    Thomas Morter-laing replied 15 years, 7 months ago 3 Members · 5 Replies
  • Aj Reuter
    February 27, 2011 at 3:37 pm
    *better for Final Cut.
    I use it for internet, and light (LIGHT) gaming. (not graphic intensive games)
  • Rafael Amador
    February 27, 2011 at 4:38 pm
    Hi Aj,
    I think that GPU is not enough to run well FC.
    Also with a 13″ you will need a second screen (unless you want to get blind) and that will rest more resources from the poor GPU.
    At least a 15″ and at least 512MB Cache GPU.
    rafael
    http://www.nagavideo.com
  • Aj Reuter
    February 27, 2011 at 5:14 pm
    I do have an external monitor. I have my MBP (the core2duo) right now and it runs fcp fine (slow rendering, but its all i could afford)
    Im curious if the other one is better and worth an extra 100 bucks?
  • Rafael Amador
    February 27, 2011 at 6:18 pm
    [Aj Reuter] “Im curious if the other one is better and worth an extra 100 bucks?
    I think that you will notice the difference.
    I’ve passed from a Core2 Duo (2.4?) to an i7 (2.6?) and runs like double fast.
    rafael
  • Thomas Morter-laing
    February 27, 2011 at 6:47 pm
    Simple answer, the i5
    Tom Morter-Laing
    Freelance Editor
    Certified Apple Product Proffessional, 2010
    http://www.depictproductions.co.uk
    Sony Z5, with Rode NTG2.
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
