Which format to shoot?
Posted by Rich Kutnick on January 23, 2013 at 9:05 pmHow does one decide the best way to shoot: 1080, 720, progressive or interlaced? I know a lot depends upon the intended use, and mine is primarily for Blu-ray production. What formats are Blu-ray compatible, then, and if some are progressive what is the mitigating circumstance that would cause me to shoot this way over interlaced? Which is the best output for Blu-ray production? Thank you in advance.
Rich Kutnick
VIDEO IMPRESSIONSRich Kutnick replied 13 years, 7 months ago 4 Members · 5 Replies -
Steve Rhoden
January 23, 2013 at 11:00 pmNo matter whats the final output, always shoot at the
highest Quality available/highest resolution.
And according to your question, Shoot 1080-Progressive.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-832-4956 -
Rich Kutnick
January 23, 2013 at 11:57 pmOK, just to clarify, then, Steve:
1) Since I understand that 1080p is not Blu-Ray compliant (and since my camcorder does not shoot this format), for all productions intended for Blu-Ray discs I should acquire at 1080i. This is what I have been doing all along.
2)…but if I want to upload a video to YouTube, for example, the feeling seems to be to use 720p. Is this the correct line of thought? If so, then, should I attempt to acquire at 720p or can I use 1080i and bump it down and deinterlace? Your thoughts and suggestions, please.
Rich Kutnick
VIDEO IMPRESSIONS -
Michael Acres
January 24, 2013 at 7:05 amshoot at 1080i if that is the best your camera can do. For youtube output 1080p or 720p files
For Bluray you have few choices but usually you would create 1080i mpeg2 or AVC files and sony vegas can create both. There are other threads here that go more into depth about it.
John Rofrano
January 24, 2013 at 12:06 pm[Rich Kutnick] “1) Since I understand that 1080p is not Blu-Ray compliant (and since my camcorder does not shoot this format), for all productions intended for Blu-Ray discs I should acquire at 1080i. This is what I have been doing all along.”
I would shoot 1080i. If you are use to panning at 60i and you change to 30p you only have 1/2 of the movement being sampled and you run the risk of your pans looking jerky unless they are very slow and deliberate. This is even more pronounced for 24p but still noticeable at 30p. Just something to be conscious of.
You are correct it depends on what you are shooting. If I was shooting fast moving objects like cars or motorcycles and my camera could shoot 1080p I would definitely shoot progressive. This is because interlaced video doesn’t do very well with fast moving objects. So there is no one-size-fits-all. That’s why cameras shoot at multiple frame rates, interlaced, and progressive, all in the same camera. You need to learn how and when to use your tools correctly.
[Rich Kutnick] “2)…but if I want to upload a video to YouTube, for example, the feeling seems to be to use 720p. Is this the correct line of thought? If so, then, should I attempt to acquire at 720p or can I use 1080i and bump it down and deinterlace? Your thoughts and suggestions, please.”
You can use 1080i and resize it to 720p. Going down is always fine, going up is not which is why I don’t see any need to ever shoot 720p unless you knew that your only delivery size was 720p. Since you want to deliver Blu-ray, you want to shoot 1080i.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Rich Kutnick
January 24, 2013 at 3:22 pmThanks for the clarification and great advice!
Rich Kutnick
VIDEO IMPRESSIONS
