Activity Forums Apple Final Cut Pro Legacy Which format should I work on in FC for SD and HD Television?
  • Which format should I work on in FC for SD and HD Television?
    Posted by Riccardo Zito on September 19, 2005 at 4:15 pm
    Hello all,
    I need to set up a broadcast monitor to a G5. Am working with final cut HD and will soon move to v.5
    I need to be able to playout projects both for SD and HD TV. In Europe I guess that means MPEG 2 and 4 respectively.
    I don’t have a video deck which means I need a converter so to be able to view work on the broadcast monitor.
    Which formats do I need to make sure the converter supports.. i.e. in what formats should I be working on in FC.?
    Thanks for your time,
    Riccardo
    Walter Biscardi replied 20 years, 11 months ago 2 Members · 1 Reply
  • Walter Biscardi
    September 19, 2005 at 6:17 pm
    It’s always best to work in whatever format you’re going to master to or whatever you shot in. For instance we shoot a show on the Panasonic Varicam so I edit in 720p but then output to HDCAM and can also output directly to DigiBeta for SD.
    If you don’t have a deck to view your projects, then you’ll need something like the AJA Kona 2 to output the signal
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
