Activity › Forums › Apple Final Cut Pro Legacy › Which format should I choose
  • Which format should I choose
    Posted by Flux Munro on December 6, 2010 at 11:39 pm
    Hi everyone,
    Thanks in advance for any help.
    I am about to start editing a compilation piece in Final Cut Pro and I’m not sure what frame rate to use.
    The footage I have is in both 25fps and 23.98fps but with the majority in 25fps. The final edit will be uploaded to Vimeo at 720p.
    What should I be considering when choosing whether to conform the fps in either direction?
    I have used Cinema Tools for conforming 50fps to 25fps, is this what I would use to change 25fps->23.98fps or 23.98fps->25fps?
    Thanks again for any help,
    Flux
    Rafael Amador replied 15 years, 9 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    December 7, 2010 at 4:23 am
    Since most is 25fps, I’d conform the 23.98 to 25.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Trevor Ward
    December 7, 2010 at 12:04 pm
    Since you’re not worried about a TV signal, and only worried about a web output, I’d go with 25. If most of it is 25, then you have less work to do.
    -trevor ward
    Red Eye Film Co.
    http://www.redeyefilmco.com
    orlando, fl
  • Rafael Amador
    December 7, 2010 at 1:40 pm
    [Flux Munro] “I have used Cinema Tools for conforming 50fps to 25fps,”
    Don’t do that.
    That only makes a 50% slow mow.
    That p50 footage have to be treated as p25. Half of the frames need to be discharged.
    [Jerry Hofmann] “Since most is 25fps, I’d conform the 23.98 to 25.”
    Not sure if that is possible. I mean, you can conform 25 to 23’98, but no sure if is possible 23’98 > 25.
    I tried once, but no option.
    rafael
    http://www.nagavideo.com
