Activity Forums Adobe Premiere Pro Which files is Premiere storing in the System directory?
  • Which files is Premiere storing in the System directory?
    Posted by Philippe Verdoni on March 2, 2010 at 5:36 pm
    My Project Settings are always set to store the captured and preview files on a partition other than the system partition and the Media Cache as well. However each time I have to restore my Operating System, when I am launching a project for the first time after the restoration, Premiere CS4 spend a lot of time to generate new files which apparently where absent from the System image used by the restoration process.
    My question is
    1 – what are these files
    2- can I change the Project settings in order that these files be stored in an other directory?
    Thank you for your assistance.
    Vince Becquiot replied 16 years, 2 months ago 2 Members · 3 Replies
  • Vince Becquiot
    March 2, 2010 at 7:36 pm
    Check: Edit > Preferences > Media and change the directory to the media cache files. It’s also good to clean these out once in a while.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Philippe Verdoni
    March 2, 2010 at 9:17 pm
    Thank you for this information. I do not understand the difference Premiere between the files stored in memory and media data base.
  • Vince Becquiot
    March 2, 2010 at 9:24 pm
    I’m bot sure I can provide an exact answer to that one, I’m no software engineer.
    The media cache folder that I pointed to above mainly stores Pek files, which basically are audio reference files. All audio is converted into a format that can easily be previewed on the timeline.
    Vince Becquiot
    Kaptis Studios
