Activity Forums Apple Final Cut Pro Legacy which drives should I use for a P2 HD job??
  • which drives should I use for a P2 HD job??
    Posted by Adrian Califf on September 3, 2009 at 12:25 am
    Hi all I hope someone can advise on this. I am about to start a P2 HD job probably shooting at 1080 25p but we are trying to decide what drives to use for the edit. We would like to ingest the media at a high resolution so as to avoid recapturing the media at the end of the offline edit. But we don’t have a raid array and would ideally like to start with FW800 drives as the job will start on an imac for a rough assembly edit and then move to a mac pro.
    I could fit internal sata drives into the 3 spare ports on the mac pro and stripe them together. But I’m not convinced a 3 way sata stripe will be fast enough.
    Also could someone please advise on the best resolution to bring the media in at. The systems will probably be running FCS3.
    I look forward to hearing your opinions..
    Adrian Califf replied 17 years ago 2 Members · 3 Replies
  • Adrian Califf
    September 3, 2009 at 3:22 pm
    Also thought I should mention that the material could well be
    AVC-Intra 100Mbits.
  • David Bogie
    September 3, 2009 at 4:50 pm
    I think you’re making some poor decisions up front without knowing why or what the unintended consequences might be. However, after you’ve been working on your project for a few months, please come back and tell us what you’ve learned and if the advice you received was of any value.
    read these:
    https://images.apple.com/pro/pdf/L317074A_FCP_Wkflw.pdf
    https://www.indiefilmpro.com/pdf/P2%20Card%20Workflow.pdf
    https://www.bloodspots.net/p2_workflow
    https://www.scribd.com/doc/7494899/DVCPro-P2-No-NonSense-Guide
    bogiesan
  • Adrian Califf
    September 3, 2009 at 4:56 pm
    The choices aren’t mine to make unfortunately, the director gets to choose what format to shoot with not me. I suspect I will import the footage initially at dvcpro-hd res onto a g-raid3 connected to the imac.
    And then re-import the footage at prores 422HQ on the mac-pro (hopefully with a g-speed fc or similar connected. If anyone has tried deleting and re-capturing p2-hd media at a higher res and has any advice I would like to hear it..
