Activity Forums Adobe After Effects Which Comp Preset to use to output to Avid DNxHD codec
  • Which Comp Preset to use to output to Avid DNxHD codec
    Posted by Michael Bayouth on January 19, 2011 at 7:22 pm
    I’m the graphic artist for that TV show “The Office” and I’m doing some motion graphics. They cut it on Avid using the DNxHD codec. First off, how do I set up my files in Illustrator and Photoshop? Is it square pixels? Is it 1920 X 1080 pixels? And then when I get into After Effects CS5 what Composition setting do I use that will conform with this codec? Is it DVCPRO HD? Thanks a bunch!! – Michael
    Thanks so much for all the great help!
    Michael
    Cory Petkovsek replied 15 years, 7 months ago 4 Members · 9 Replies
  • 9 Replies
  • Kevin Camp
    January 19, 2011 at 8:06 pm
    dnxhd is full raster (or square pixel), there is no horizontal scaling of the image like hdv, dvcprohd, etc… so you’ll want square pixel for your comp setting.
    as far as which preset or comp settings to use, it depends on the the frame size and frame rate that they produce the show in… i assume that since the office is on nbc, that it is shot in 1080. if that’s true then the comp size would be 1920×1080.
    what i don’t know is what frame rate…. it could be 1080i, which would be 29.97fps, and rendered with fields (upper 1st). or they could be shooting in 1080p, which would most likely be 23.976fps (though you can shoot in 29.97 progressive), either way you would render progressive.
    so you really should ask.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Michael Bayouth
    January 19, 2011 at 8:14 pm
    Thanks so much for your speedy reply!
    The specifics on the codec are 1080p / 23.976 175 10-bit
    Actually they didn’t say “go make us some graphics” I just made them any way I could and they got approved. Now I have to give it to them so they can use it. Yikes!
    My main question is: what preset to use in AE CS5? Is it a DVCPRO preset? If so which one? I loaded their codec fine and can see it when I render under “Format options”.
    BTW, what is HV resolution? (dumb Q I know!)
    I’m kinda green to motion graphics. Mainly it’s the composition setting Q.
    Michael
  • Michael Bayouth
    January 19, 2011 at 8:27 pm
    Thanks Kevin!
    So basically I can leave the comp setting in CS5 set to “Custom” and just make sure it’s 1920 X 1080?
    Thanks again!
    Michael
    Michael
  • Michael Bayouth
    January 19, 2011 at 8:29 pm
    Thanks Kevin!
    Thanks again!
    Michael
    Michael
  • Kevin Camp
    i don’t know if there is actually a preset for this, but what you want is:
    comp size: 1920×1080
    par: square
    frame rate: 23.976
    when you render you’ll choose quicktime, click the options and choose the dnxhd as the codec/compression and then choose 1080p/23.976 175 10-bit for the resolution.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    January 19, 2011 at 8:31 pm
    i replied to your response to dave, but you’s also want to set the frame rate to 23.976 (based on your response to dave…)
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Michael Bayouth
    January 19, 2011 at 8:32 pm
    You guys rock! Thanks so much!
    Michael
    Michael
  • Jon Bagge
    January 20, 2011 at 1:08 am
    And make sure you render in 16-bit (or 32) since you’re delivering in 10-bit.
    Merry Christmas! https://www.vimeo.com/18012728
    Jon Bagge – Editor – London, UK
    Avid – FCP – After Effects
  • Cory Petkovsek
    January 20, 2011 at 1:41 am
    Michael>> I’m kinda green to motion graphics.
    What I’d really like to know is how you got the job then??
    Cory
    Cory Petkovsek
    Corporate Video
